x7853 sound problems
1 REPLY 1
alwaysfish
Message 1 of 2
Message 1 of 2
I have a strong feeling that a subwoofer is not working on my x7853. It doesn't produce any sound. Is there any setting to turn on/off subwoofer in the BIOS? And how can i test if subwoofer is dead?
1 REPLY 1
Bodgekin
Message 2 of 2
Message 2 of 2
Hi @alwaysfish
I don't know if it is possible to turn off a subwoofer in the BIOS, but I think you'll be able to test the subwoofer in Windows using the audio driver. I think your system is equipped with a realtek soundcard (to my knowledge most, if not all, Medion systems have Realtek audio), if so, you can start the Realtek HD audio config tool, it offers a test mode with which you can test each speaker individually.
Kind regards,
Bart
1 REPLY 1
