x40 Beast - cooling issues
4 REPLIES 4
Thenewb
Message 1 of 5
Message 1 of 5
hey guys i seem to be having issues with the cooling on my x40, I have the watercool kit for it and when thats all setup things seem fine. When im not using it my cpu temp seems to go sky high, even when I have the fans on max. There is no obstruction to the air flow vents and I even have the laptop slightly tilted to allow air underneath, With a game open on the main windown my cpu usage was at 20% but the cpu temp was 94 degrees C, surely something is wrong?
4 REPLIES 4
Message 2 of 5
Message 2 of 5
Hi @Thenewb ,
I´m not sure if both of them do exactly have the same ERAZER Beast machine, but maybe @Mrdanky or @Odarnok can share their thoughts one this one. The discussed water cooling solutions in this thread
Can you also tell me, if you already updated your Bios & EC upt to V N1.23MED08_EC_1.14.00_20230801?
Otherwise you can download it on our service webpage
Disclaimer:
For any errors, caused by the execution of this update, MEDION doesn´ t accept any responsibility for damage or loss of data.The customer agrees with that fact by executing the update.
Cheers
Thenewb
Message 3 of 5
Message 3 of 5
Im having to use XMG's bios version N.1.23A12 I do have the watercooling kit from XMG because Medion dont sell the kit for the UK market 😞
Thenewb
Message 4 of 5
Message 4 of 5
that with water cooling, room temp probably about 20 Degree Celsius
Lozep
Message 5 of 5
Message 5 of 5
I have the same issue. Idle, the CPU go up to 94 degrees. When playing, go down.
Maybe its a throttle
4 REPLIES 4
