upgrade laptop SSD
2 REPLIES 2
and76
Message 1 of 3
Message 1 of 3
upgrade laptop SSD
Hello. I have a Medion Erazer Deputy P10 laptop (core i7 10th gen, 512 SSD), with MSN 30029942, and I would like to know where I can find available slot information to upgrade to another SSD or RAM in this model. I can't find videos on Youtube. Thanks.
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
@and76
I am afraid you can  not upgrade the permanent memory. The only way would be, to replace the build in M.2 SSD for a model with greaterr capacity.
Or by using a external housing for a M.2  SSD; which is conveniant small in size, and also quite fast.
Here is a test from a german magazine :
https://www.computerbild.de/artikel/cb-Tests-Notebooks-Netbooks-Medion-Erazer-Deputy-P10-Test-Review...
RAM you can upgrade to 2x16 GB:
2x 8192 MB DDR4 SO-DIMM (PC4-25600/ 3200 MHz) (2/2 Slots covered; 32GB max.)
Cheers, daddle
2 REPLIES 2
Message 2 of 3
Message 2 of 3
@and76
Cheers, daddle
and76
Message 3 of 3
Message 3 of 3
Many thanks for your kindly answer and support!
2 REPLIES 2
