op 19.04.2020 20:41
op 19.04.2020 21:02
op 19.04.2020 21:02
Hello @darejkt and welcome
what kind of PC do you have?
Please enter the type / MSN number.
Is there an F key that is stuck
bye Fishtown
op 19.04.2020 21:10
op 19.04.2020 21:10
thanks first for the reponse.
my pc is an erazer x67123 with i5 and gty 1660ti
op 19.04.2020 21:15
op 19.04.2020 21:15
anotger thing, if i go in bios i see that nvme ssd isnt in motherboard, but i open the pc and i have an nvme. only 512gb nvme
op 19.04.2020 23:37
op 19.04.2020 23:37
Hi @darejkt
please see / search for yourself on google:
"ssd is not shown in UEFI"
sorry, I would have to translate everything from German that is too complex
bye Fishtown
op 20.04.2020 11:42
op 20.04.2020 11:42
In an UEFI PC the harddisk or ssd is not necessarily shown in UEFI. Sometimes the disks are listet in the page advanced or Secutiy, depending on your UEFI
Important is if you can see an entry "WindowsBootManager" on the page "Boot".
The fault which makes you booting into Bios is that the UEFI bootroutine cannnot find a valid bootable medium, so it sz´tarts into UEFI.
You also could try a so called "Reststromentladung", to drain all capacitors on board and from the power unit.
Therefore disconnect all cables, also the wall outlet, from your PC. And then press the Power Button for about 15 seconds.
I also would disconnect the M2 SSD, an reseat it. The same you should do with your memory sticks.
regards, daddle
21.04.2020 09:02 - bewerkt 21.04.2020 09:07
This English F.A.Q. may also be useful.
Greetings,
Luke
