md 34635 medion erazer
3 REPLIES 3
bograt2021
Message 1 of 4
Message 1 of 4
Hi, I want to remove the graphics card and want to use the on board graphics. However i cannot enable IGD and i have  get output on HDMi but  I do on dp and also the vga. How do i get an output on the hdmi ? As i use three monitors .
Also is there a link to ensure the bios and drivers are up to date.
MSN is 10024316
Tags (3)
3 REPLIES 3
P1a5ma
Message 2 of 4
Message 2 of 4
Hi Bograt2021,
Have you removed the graphics card already? Or are you trying to use the IG with the card still in place?
Thanks!
bograt2021
Message 3 of 4
Message 3 of 4
Hi I removed the graphics card and no hdmi output from the motherboard other two are fine
Thanks
mats749
Message 4 of 4
Message 4 of 4
Hi Bograt2021,
If your getting display from the onboard VGA port and Display port then it would suggest a problem with the HDMI.
Please contact your local Medion support center to arrange for a service.
You can access the UK support here
Thanks
Mats749
3 REPLIES 3
