keyboard light
5 REPLIES 5
PeterGuo
Message 1 of 6
Message 1 of 6
keyboard light
I closed keyboard light by using Fn+ and changed power on light colour. I can change power on light with different colour by using Fn+ but keyboard light is off. How to switch on keyboard light ?
1 ACCEPTED SOLUTION
Message 6 of 6
Message 6 of 6
god morgon @PeterGuo
This is how you set it up in the Control Center.
Hejdå Fishtown
5 REPLIES 5
PeterGuo
Message 2 of 6
Message 2 of 6
My laptop model is erazer major x10
Message 3 of 6
Message 3 of 6
Hello @PeterGuo and welcome
I don't have your device. Isn't this possible in the control center (FN+F9)?
Otherwise check the bios. or try brightness using the keyboard
to turn this on.
does FN + spacebar button have a reaction?
bye Fishtown
PeterGuo
Message 4 of 6
Message 4 of 6
Hello Fishtown,
Thanks your tips. I have the exact keyboard layout you showed in your reply.  I tried them but it looks nothing happed.
 Happy holiday!
BR/Peter
PeterGuo
Message 5 of 6
Message 5 of 6
Hello again,
I got the two different manuals for the same model laptop " Erazer major X10 ". Following picture is information how to make keyboard backlight brighter or darker. The left side is Swedish version (Because I live in Sweden ) and the right side is English version. It is interesting right ?
It doesn't follow any manual to control keyboard backlight.  But I can use Fn + "+" to change "power on" light colours: there are 8 different colours and use Fn + "0" make "power on" light flash. It is nothing happened with keyboard backlight.
By the way, how to contact with customer service? It isn't easier to reach them.
Have a nice day.
Peter
Message 6 of 6
Message 6 of 6
Hejdå Fishtown
5 REPLIES 5
