X5361 G support samsung 970evo plus?
5 REPLIES 5
30lucas30
Message 1 of 6
Message 1 of 6
ive been having abit of trouble and dont know too much im affarid, ive got a Erazer X5361 G with i think a B250H4-EM mother board, i see what looks like the right M.2 connection plug but the samsung drivers dont detect it and neither does my bois by the looks of it. any ideas on how i can get it to work. thanks
1 ACCEPTED SOLUTION
30lucas30
Message 6 of 6
Message 6 of 6
Okay everyone, I got it sorted, had to remove my old HDD, swap bois from RST to AHCI disable CSM. Change boot to USB and install a fresh windows 10 off a stick. Once installed windows, installed the Samsung NVMe driver and magician. Then restarted my computer and changed the boot to the 970evo and re enabled CSM. Boom mind blown I'm a noob with no experience in BOIS. So much for plug and play. Can anyone give advice on disk cloning? Thanks
5 REPLIES 5
Luke
Community Manager
Message 2 of 6
Message 2 of 6
Hello @30lucas30 and welcome to our Community.
Your mainboard offers these M2 interfaces:
  • • 1x M.2 NGFF1 2260 and 2280 size with flexible standoff, SATA mode only
    • 1x M.2 NGFF2 E-Key 2230 for WLAN only
    • 1x M.2 NGFF3 for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280
Hope this helps,
Luke
30lucas30
Message 3 of 6
Message 3 of 6
Erm, a little bit I think, so it should support this internal storage then? Why cant I get mine to work? Thanks
Luke
Community Manager
Message 4 of 6
Message 4 of 6
Hello @30lucas30 ,
Yes, according to Samsung`s Data Sheet it should be compatible. You may contact their
support to get further information.
Cheers,
Luke
30lucas30
Message 5 of 6
Message 5 of 6
@Luke  thanks i was installing hardwear in wrong connection,  i can now see the device in disk management but still cant install drivers do i need to change any settings?
thanks
30lucas30
Message 6 of 6
Message 6 of 6
5 REPLIES 5
