op 27.08.2025 23:12
op 27.08.2025 23:12
Hi all,
I have a beast X40 (MD62611) UK which came with ddr5 32GB 5600Mhz RAM which ran great. However, every now and then I was maxing this out so have bought the Corsair Vengeance DDR5 64GB 5600MHz RAM (2x 32GB). Once installed, it only runs at 5200MHz! There seems to be no option of XMP in the BIOS N1.10MED09 (latest) which would allow me to set this to the 5600MHz.
My Question is, is this hard set within the current BIOS when you have 64GBs of RAM installed or is there a way to override this?
op 28.08.2025 08:51
op 28.08.2025 08:51
I guess the 5200MHz are the maximum speed the chipset allows. Or the Bios restricts to. As a safety feature.
I also think the original 2x16 GB RAM also run at 5200 MHz. only.
You didn't specify this. XMP RAM ist not configurable .
Bye, daddle
op 29.08.2025 18:08
op 29.08.2025 18:08
Hi diddle, thanks for the response.
The original 2x 16GB runs at 5600MHz fine, confirmed by HWINFO.
Just don't get why it's runs 400MHz slower when you double the amount of RAM.
Any other help would be gratefully received.
op 17.09.2025 14:29
op 17.09.2025 14:29
I got the same Issue.
I can only guess its because of Single Sided RAM (SSR)/Double Sided RAM(DSR).
I have 2x16GB DDR5 5600MHz SSR installed and it works like a charm.
If i install 2x32GB DDR5 5600MHz DSR it only works with 5200MHz.
I also got my hands on one 32GB 5600MHz SSR and with that installed it works with 5600MHz as well.
But i don't know where to get another SSR :/.
Can find any specific RAM information on SSR/DSR 😕
op 17.09.2025 14:31
op 17.09.2025 14:31
Here the Task manager Stats of my current BeastX40 RAM setup running on 5600Mhz
op 20.09.2025 11:01
op 20.09.2025 11:01
In the Erazer control center, there is the possibility to unlock the RAM functions in the original Medion BIOS N1.10MED09. There you can also manually set the RAM back to 5600MHz.
op 20.09.2025 18:50
