X15809 CPU upgrade.
3 REPLIES 3
FunkyMonkey95
Message 1 of 4
Message 1 of 4
X15809 CPU upgrade.
Does anyone know if the BIOS and motherboard power delivery on the Erazer x15809 would support an i9-9980hk? I know it's BGA and it'll need resoldering on.
The i9 has the same TDP as the i7-9750h currently in the laptop and power usage is very similar according multiple sources. Any help would be greatly appreciated so thanks in advance.
1 ACCEPTED SOLUTION
Message 2 of 4
Message 2 of 4
Hello @FunkyMonkey95 and welcome
You have an x15809 / MDxxxxx / MSNxxxxxxxx (Tong Fang TFG GK5CQ7Z) with an Intel Core i7 Mobile i7-9750H 2.6 GHz.
There was also an x15809 / MD61529 / MSN30026787 (Tong Fang TFG GK5CQ7Z) with an Intel Core i9 Mobile 9980HK 2.4 GHz .
So it should work.
bye Fishtown
here's an example:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiYtt7KnKbvA...
3 REPLIES 3
Message 2 of 4
Message 2 of 4
So it should work.
bye Fishtown
here's an example:
FunkyMonkey95
Message 3 of 4
Message 3 of 4
Excellent, thanks for the help. I can imagine they will use the same universal BIOS. Just need to check if they use the same 230w Power Adapter. Hopefully the motherboard design is identical with the same power delivery.
Thanks again @Fishtown.
Message 4 of 4
Message 4 of 4
Hi @FunkyMonkey95
the same Power Adapter: AC - DC Power Supply, 230 W (MSN 40070452)
In: U~ = 100-240 V (50/60 Hz)
the same Bios/Chipset: Intel HM370
bye Fishtown
3 REPLIES 3
