Upgrade storage on Erazer X17801
3 REPLIES 3
Aluz24
Message 1 of 4
Message 1 of 4
Hello everyone,
I bought a new laptop and i need to upgrade the storage. I was thinking about buiyng a M.2 but i can't find anywhere the specs that i need to buy the right one.
Can you help me please?
p.s: I'm sorry i know this is not in the right forum but i don't know how to delete this 😞
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @Aluz24 and welcome to the forum!
Can you please provide the MSN number of your product so I may be able to help you finding its specs?
The MSN is an 8-digits number printed on a label underneath your product and it normally starts by 100, 300 or 500
Regards,
Gehringer
Aluz24
Message 3 of 4
Message 3 of 4
Hi @Gehringer!
Thanks for your interest. My MSN number is 30026685.
Have a nice day!
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @Aluz24 ,
please find below the specs of the SSD that comes with your machine:
Samsung PM981 MZVLB512HAJQ
* Form Factor: M.2 2280-M
* Key: M
* Capacity: 512 GB
* Bus System: PCIe 3.0 x4 32Gb/s
* Supply Voltage / Tolerance: +3.3V ± 5%
* Voltage Ripple / Noise (max.): 100mV p-p
If you want to upgrade it, you should make sure that the new SSD is compatible with these specs.
I recommend you to buy it from the Medion spare parts e-commerce here
Alternatively, make sure the seller would accept a return/refund in case you need it, just to be on the safe side.
Regards,
Gehringer
3 REPLIES 3
