Upgrade RAM on a Deputy P40
6 REPLIES 6
Max45475
Message 1 of 7
Message 1 of 7
Hello !
I have a ERAZER Deputy P40 (MD 62551)
MSN: 3003 5597
I have 16 Go RAM with the stock RAM so 2x8 Go of SODIMM 4800 Mhz DDR5.
Can I upgrade to 2x16 to have 32 or even 2x32 to have 64?
I saw that some MEDION computers have a limit of RAM so I better be sure before buying new RAM.
Thank you for your help!
Have a good day
2 ACCEPTED SOLUTIONS
Message 2 of 7
Message 2 of 7
@Max45475
Your Deputy P40 takes a maximum of 32 GB RAM, (2x16GB)
The specs are:
2x 8192 MB DDR5 SO-DIMM (PC5-38400/ 4800 MHz) installed; (2/2 Slots covered; 32 GB max.)
Bye, daddle
Message 4 of 7
Message 4 of 7
Hello @Max45475 et bienvenue/ and welcome.
Your Deputy P40 is based on a Clevo V155RNDQ.
According to their clevo service manual, it should also support up to 64GB if the CPU supports it, and your i5-12450H can.
au revoir / bye Fishtown
6 REPLIES 6
Message 2 of 7
Message 2 of 7
@Max45475
The specs are:
Bye, daddle
Max45475
Message 3 of 7
Message 3 of 7
Thank you, have a good day!
Message 4 of 7
Message 4 of 7
Max45475
Message 5 of 7
Message 5 of 7
Ok good to know!
Thank you !
Message 6 of 7
Message 6 of 7
@Max45475
@daddle  schrieb:
Your Deputy P40 takes a maximum of 32 GB RAM, (2x16GB). The specs are:
Diese Wert gibt Medion für den Deputy P40 in seiner Datenbank im Intranet an. Diese Werte sind getestet und für sicher funktionierend angegeben worden. Auch für deinen Rechner mit dem  Clevo Barebone V155RNDQ.
Möglicherweise sind ja die Werte für den Medion Abkömmling reduziert worden.
Aber eine Frage; wofür bräuchtest du 64 GB an RAM?  Kostet viel, frisst viel Akkukapazität und wird nur in den allerseltensten Fällen ausgenutzt.
Gruß, daddle
English:
Medion provides this value for the Deputy P40 in its intranet database. These values have been tested and confirmed to be working. This also applies to your computer with the Clevo Barebone V155RNDQ.
The values for the Medion derivative may have been reduced.
But one question: why would you need 64 GB of RAM? It costs a lot, consumes a lot of battery charge, and is only used in the rarest of cases.
Max45475
Message 7 of 7
Message 7 of 7
@daddle
Yeah I will go with 32 GB. 64 was more out of curiosity but realistically I don't need it.
6 REPLIES 6
