Trouble removing back panel from Defender p15
5 REPLIES 5
Ticket
Message 1 of 6
Message 1 of 6
The laptop is a Medion Erazer Defender P15 MD62294, MSN 30031897
(a barebone clevo NH77EPY-M)
I want to remove the back panel to add a SDD nvme data drive.
Following the instructions in the service manual, I have remove the 15 screws.
Two screws are for securing the keyboard - I have not removed them.
But the panel seems to be stuck firmly on.
The instructions on how to pull the panel off don't make much sense to me.
Is there some special technique for removing the panel?
Tags (3)
1 ACCEPTED SOLUTION
Ticket
Message 4 of 6
Message 4 of 6
Well, the service manual (NH77ERQ SM 20210311.pdf) says remove 15 screws.
It did not say remove the screws that secure the keyboard.
But as noted, it makes no sense to leave those two keyboard screws in, so I removed them as well.
By pressing down onto the circuit board openings in the battery compartment with one hand, and pulling up the bottom edge of the panel with the other hand, I was able to loosen the panel.  Careful prising around the edges, starting from where a gap has appeared, enabled me to pull off the panel.
So you need to remove all 17 screws!
The service manual does not make that clear.
Also, the service manual says screws 5 & 6 should be removed at an angle. It should say screws 4 & 5 !
(these are two of the screws inside the battery compartment).
So with the above advice, this is solved.
NOTE: the laptop lid is easily scratched, so place the laptop on a soft cloth before doing all of the above!
5 REPLIES 5
Message 2 of 6
Message 2 of 6
@Ticket
Without having this PC myself, it sounds illogical to me t have the two screws still siitting in place. They are stuck through the bottom to the upper half, so they also hold the bottom panel as well fixated. If someone knows more, please add here..
Cheers, daddle
Message 3 of 6
Message 3 of 6
Hi @Ticket
Remove the lower case, you have already taken out the screws
look service manual : Removing the Hard Disk Drive  Page 2 - 7
bye Fishtown
Ticket
Message 4 of 6
Message 4 of 6
Message 5 of 6
Message 5 of 6
congratulation @Ticket
opening the floor is a follow-up step. before that came: Removing the Keyboard Page 2-6😉
But you still have to answer one question. (From another post) are connections available for an HDD?
Bye Fishtown
Ticket
Message 6 of 6
Message 6 of 6
"opening the floor is a follow-up step. before that came: Removing the Keyboard Page 2-6"
Understood, but I had no intention of removing the keyboard (!) so that step was skipped.
As for the HDD drive, a drive connector does exist, see picture at end of this post:
https://community.medion.com/t5/ERAZER-Gaming/Defender-P15-notebook-how-to-fit-additional-data-drive...
However, I did not try to connect a SATA drive to it, so I don't know if it is functional or not.
5 REPLIES 5
