Storage update - Scout E20
1 REPLY 1
ALS83
Message 1 of 2
Message 1 of 2
Hello.
I'd like to know what storage upgrades are possible in the model below. Is it possible to add an M.2 or SATA SSD in addition to the 512GB M.2 SSD already present?
Also, where can I find the service manual for this model?
Thank you for your help !
Medion ERAZER Scout E20 (MD 62521) FR
MSN: 3003 5377
1 ACCEPTED SOLUTION
Message 2 of 2
Message 2 of 2
Hello @ALS83 and welcome
You have an M.2 SSD PCIe GEN 4x4 512GB installed.
You can't install a second M.2, but you may need a 2.5" HDD/SSD. But you'll need an installation kit for that. It's probably available from the Medionservice shop.
the contribution to this: https://community.medion.com/t5/ERAZER-Gaming-NBs/suche-Anleitung-Einbau-HDD-Festplatte-im-Erazer-Sc...
Hello @flumy  ,
die Installation wurde erfolgreich abgeschlossen und können Sie hier die MSN-Nummer des Installationskits angeben? Danke schön.
did the installation work for you and can you provide the msn number of the installation kit here, thank you.
You can now upgrade the RAM/RAM to 2x 8192 MB DDR5 SO-DIMM PC5-38400/4800 MHz: 2/2 slots covered; 32GB max.
Drivers, spare parts, other items can be found here: https://www.medion.com/fr/service/product-detail/30035377
Here is a useful service manual (Clevo V170RNCQ) so that you do less damage.
Attention: there are links to aggressive advertising sites, the actual zip only loads with the second or third click on the download button. Download file
https://www.file-upload.net/download-15228795/V170RNCDESM20230306.zip.html
au revoir Fishtown
1 REPLY 1
Message 2 of 2
Message 2 of 2
Hello @flumy  ,
au revoir Fishtown
1 REPLY 1
