SSD Slot in Erazer Defender P50 MD62596
6 REPLIES 6
DoraBora
Message 1 of 7
Message 1 of 7
Hey,
I just ordered a Defender P50 MD62596. But since it only has a 512 GB M.2 SSD, I would like to upgrade the storage to at least 1 TB. So I was wondering whether this laptop has a 2nd empty SSD slot, or not (I tried to search for some info online, but I didn't find anything really reliable). And if there is an empty slot, is it a M.2 slot, or a SATA one, and is there any size restriction? I'd like to order the SSD before actually receiving the laptop.
Thanks a lot!
1 ACCEPTED SOLUTION
Message 2 of 7
Message 2 of 7
Hi @DoraBora and welcome
there is a second slot for one:
M.2 PCIe Gen3 x4 Solid State Drive (SSD)
You have a 512GB PCie installed. Some competitors also sold the barebone Clevo NP70RND1 with 1TB. should go as.
bye Fishtown
6 REPLIES 6
Message 2 of 7
Message 2 of 7
bye Fishtown
DoraBora
Message 3 of 7
Message 3 of 7
Thank you very much! This answers perfectly to my question (and the picture is much appreciated!).
Have a good day!
Nils420
Message 4 of 7
Message 4 of 7
Is it possible to use a M2 with heatsink or better buy without ?
@Fishtown
I have a defender p50
funstaf
Message 5 of 7
Message 5 of 7
Good evening, I don't think we can put a heat sink because on the back panel there are metal plates to make a heat sink.
Nils420
Message 6 of 7
Message 6 of 7
Wo bekomme ich die Software Downloads zu meinem gibt's irgendwie keine Downloads
Defender p50
Msn
40090866
Message 7 of 7
Message 7 of 7
Moin @Nils420
unter der MSN 40090866 mit der MD62616 ist auf der Medion Service Seite leider nichts gelistet.
Du könntest aber mit der MD62616 dort suchen und ein Schwestermodell und deren Treiberpaket nehmen welche sich alle auf ein barebone clevo NP70RND1 beziehen.
https://www.medion.com/de/service/product-detail/30038361
Auch müsste sich auf deinen Rechner auf Laufwerk D (Recover) ein Ordner mit Treiber befinden , schau dort unter Drivers nach.
6 REPLIES 6
