05.12.2024 10:12
05.12.2024 10:12
Im looking for the correct battery to replace one that had to be removed, tried calling service and emailing them getting nowhere...
Can anyone point me in the right direction? ive found a 6-87-NP5KS-53G00 but not sure if this would work as the one removed was a G01
Thanks
05.12.2024 20:20
05.12.2024 20:20
Hi @AD_ and welcome
You can find the right battery in the Medion service shop, where it is listed, but is currently not in stock. It may take some time due to technical problems with the shop. However, you should still send out your order request.
https://www.medion.com/medionserviceshop/en/p/battery-battery-4-cells-15-4-volt-3-51-ah-40081753
bye Fishtown
05.12.2024 20:20
05.12.2024 20:20
Hi @AD_ and welcome
bye Fishtown
06.12.2024 07:50
