Repairs under warranty
1 REPLY 1
Khuram
Message 1 of 2
Message 1 of 2
Hi,
My Erazer gaming notebook is still under warranty, how do I go about arranging a repair?
I was opening my laptop screen to login & a small crack appeared from the top left, which has damaged the display.
The laptop was not dropped, neither was too much pressure used when opening the laptop display.
I've had the laptop for close to 10 months, this is the first issue I have come across.
Any help would be appreciated.
Thanks
1 REPLY 1
Message 2 of 2
Message 2 of 2
Hi @Khuram,
due to tthe fact, that this is a user-helps-user community it would be the best option for you, to contact our customer service with your issue.
Regards,
1 REPLY 1
