P15601 Erazer notebook RAM query
3 REPLIES 3
pete3bs
Message 1 of 4
Message 1 of 4
I have recently purchased a P15601 notebook and wish to up grade the RAM from 8gb to 16gb. I cant find any information on this model and took a while to find out which RAM was needed, I however cant find out how to access the RAM ports on my notebook? there is no separate compartment you can open, the whole bottom seem to be one section? Any help would be much appreciated as not very skilled at this kind of thing 🙂
Tags (2)
1 ACCEPTED SOLUTION
pete3bs
Message 3 of 4
Message 3 of 4
Thank you I will try to take bottom off tomorrow.
pete
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@pete3bs
Hi Pete,
you do need  1x 8192 MB DDR4 SO-DIMM (PC4-21300 / 2666 MHz); 8 GB RAM ist built in, you can go up to 16 GB RAM maximum.
I don't know this Notebook, I assume you have to dismantle the complete bottom. But check e.g. in YouTube, if you v´can find some videos about your Clevo Barebone  CLV NH55RHQ-M.
regards, daddle
pete3bs
Message 3 of 4
Message 3 of 4
pete
Message 4 of 4
Message 4 of 4
Hi @pete3bs and welcome
look here the service manuel:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=2ahUKEwjKzevqlf3oAhXLm6QKHRevBjk...
is easy to open
Bye Fishtown
3 REPLIES 3
