Need Help With 3 Beep Sound Problem.
2 ANTWORTEN 2
Infz
Nachricht 1 von 3
3.205 Aufrufe
Nachricht 1 von 3
3.205 Aufrufe
Hello,
Recently in the last weeks I've had a few problems with my pc occurring. I've been coming back to my pc beeping 3 times with a pause. This have happened about 4 times  in the last 1-2 weeks. I've waited to see if it disappears but it doesn't look like it. I still have warranty on the pc and it was purchased 4th of April 2021.
I'm not 100% sure but I think the beeping sounds occour when leaving the pc on, for example: pausing a youtube video and just leaving it on for a bit and then coming back to the beep sounds and a black screen without being able to turn it on. I just had to restart it on the pc itself for it all to go away.
Anyone know how to solve this problem? If so it would be very appreciated :).
Name: ERAZER ENGINEER P10 MD34912
MSN: 10023715
Specs:
CPU: INTEL I5-9400F
COOLING:
AIR COOLER
MAINBOARD: INTEL B360 BASED
MEMORY: 16GB DDR4-3200
GRAPHICS: NIVIDIA GEFORCE RTX 2060 6GB
LAN: GIGABIT LAN
2 ANTWORTEN 2
Gehringer
Retired
Nachricht 2 von 3
3.198 Aufrufe
Nachricht 2 von 3
3.198 Aufrufe
Hi @Infz ,
it looks like your unit is beeping when it enters sleep mode.
To try to solve the problem, please do this test:
- Type "Control Panel" on your windows search bar and open it
- Make sure your icons are displayed as "categories"
- Select Hardware and sound
- Select Change system sounds
- Under Sound Scheme, change the drop down list from the standard "Windows 10" to "No sounds"
- Select Apply
- Restart your unit
Regards,
Gehringer
Infz
Nachricht 3 von 3
3.185 Aufrufe
Nachricht 3 von 3
3.185 Aufrufe
Hey, thanks for your answer. I did what you said. I just want to be sure there's no problem with my pc since when it screen turns black there's no other way than restarting it.
This might fix the sound beeping but is there still a problem?
2 ANTWORTEN 2
