Medion Erazer P7651 - Slow USB detection
3 REPLIES 3
springs
Message 1 of 4
Message 1 of 4
Hi all,
I've got an Erazer P7651 which for most of the time i've had it has had the following issue.
When inserting / removing anything from the usb ports it takes some time for the machine to recognize it.
The usb-c port seems to be quicker but it's not always convienient to carry around a hub for it.
I've reinstalled windows 10 with the ISO straight from Windows and not Medion. Looking at device manager it does show 3 unknown devices but it doesn't give any hardware-id's to go searching on the web for it
has anyone had similar issues with their machines?
3 REPLIES 3
P1a5ma-
Message 2 of 4
Message 2 of 4
Hi Springs,
Are you using windows 10 or 11? from your description, it does suggest a possible driver problem.
Most drivers now are distributed via windows updates.
How do I update device drivers? - MEDION Community
Thanks
springs
Message 3 of 4
Message 3 of 4
It's still on windows 10.
I've gone through the driver updates and there is nothing to update / install.
I've also booted into a ubuntu live image and even that isn't picking up my KB / Mouse via usb
mats749
Message 4 of 4
Message 4 of 4
Hi Springs,
Do you have the MSN of this Erazer?
Thanks
Mats749
3 REPLIES 3
