27.07.2020 18:22
27.07.2020 18:22
MSN:30026175
I have the Medion Erazer P6606 with the MSN mentioned above.
I have looked around and cannot find any instructions on how to open this notebook for cleaning or a RAM upgrade (providing it is permitted to do so yourself under warrenty).
If anyone has any information that would be helpful regarding this please let me know.
30.07.2020 17:40 - edited 30.07.2020 17:42
Most laptops gives access to RAM and HDD after removing first panel from the back. Some screws however are covered by a self adhesive rubber cap to mimics a warranty seal. For cleaning it might be a bit tricky.
At any case take consideration about opening the laptop in terms of warranty.
Cheers
