Medion Erazer Major X20 Intel(R) Dynamic Tuning Technology Device driver error
8 ANTWOORDEN 8
zardozthestoneg
Bericht 1 van 9
2.598 Weergaven
Bericht 1 van 9
2.598 Weergaven
Hi All,
For some time, I am having an driver error issue with Intel(R) Dynamic Tuning Technology Device. As you can see per below screen shot from my device management application, there is an issue with component and updater both.
When I try to update the driver from the device management, it always fails. When I try to find a driver from Intel pages, they directing everyone to manufacturer of the notebook and they indicate driver of this should be provided by manufacturer. When I check the driver pack in Medion service portal per MSN number, there is no such dedicated driver. In addition to that, I am not the only one who have the issue.
My CPU sometimes overheats and fan of my notebook has greater rpms due to, I mean even only during office works. I do not know this is related with this driver but I will try updating this driver and check the heating issue later on.
I've already updated Bios and EC both nothing changed so far.
Kindly request your help.
@Major_ToM I hope you can help on this...
Model: Medion Erazer Major X20 (MD62525)
MSN: 3003 5497
8 ANTWOORDEN 8
Bericht 2 van 9
2.502 Weergaven
Bericht 2 van 9
2.502 Weergaven
Hi @zardozthestoneg ,
it´s quite difficult to predict the caus of your errors without knowing the 8-digit- MSN article number (3003xxxx) and also what happened before and especially not knowing, which Intel application causes the driver conflict.
If you want to prevent running a manual, clean installation with the the MS Media Creation Tool, did you try to performa rollback to an earlier systempoint, where everything was in fine shape?
Since Windows 10 we (just) provide the original drivers which have been part of the software master. Further updates/applications  are provided by the Windows Update functionallity or can be downloaded from the Microsoft App Store.
Cheers
zardozthestoneg
Bericht 3 van 9
2.282 Weergaven
Bericht 3 van 9
2.282 Weergaven
Hi Tom,
I already shared my MSN number within my first entry: MSN: 30035497
When I look for possible solutions in Intel pages, I realized they suggested to look that issue with computer manufacturer and updated drivers should be provided by them. That's why I am asking help here. After I realized the issue, I have completed lots of Windows update but it did not fix the issue. Beside, I do driver updates from Intel pages as well. But it did not fix it again.
BR,
Angerfist45
Bericht 4 van 9
2.142 Weergaven
Bericht 4 van 9
2.142 Weergaven
Dear @zardozthestoneg,
I have the same problem with my X40 Beast and I think we're a little further along here. Everything is in German, but if necessary, just use a translator. Otherwise, you are welcome to contact me privately.
Probleme mit Beast X40 und Treiber für Intel(R) Dynamic Tuning Technology Device / Updater
In short: A Window driver update is responsible for this. The Medion recovery with the Windows 11 installation WITHOUT internet helped. Then you have to stop Windows driver updates via the registry. Only then connect to the Internet and install all other updates. There were no more errors in Device Manager.
I hope it helps. Best regards
Bericht 5 van 9
1.726 Weergaven
Bericht 5 van 9
1.726 Weergaven
did not got emntioned about your answer, because there was the @-Sign missing in front of my username.
All in all I´m curious, if your prob already got fixed, of if you still nee assistance.
Cheers
zardozthestoneg
Bericht 6 van 9
1.588 Weergaven
Bericht 6 van 9
1.588 Weergaven
Hi @Major_ToM ,
I have not tried the solution suggested by @Angerfist45 yet.
But to be honest, just to fix this, I do not want to make a full recovery. That's a lot of time and work to do. And beside, I do not want to set everything again.
Is there something else you would advice? Such sharing a driver file which can help to recover it?
Thanks and BR,
Cem
zardozthestoneg
Bericht 7 van 9
1.581 Weergaven
Bericht 7 van 9
1.581 Weergaven
Hi @Major_ToM  and Hi @Angerfist45
After my last reply, I have downloaded the driveridentifer program and found the necessary driver for it. After I updated the driver, it is fixed now.
I suggest this method whoever faces the same problem.
Thanks again your helps!
BR.
Cem
Bericht 8 van 9
1.559 Weergaven
Bericht 8 van 9
1.559 Weergaven
Hi@zardozthestoneg,
this is excellent news, are you talking about the Intel Driver & Support Agent?
This is alsways a good idea
Cheers
zardozthestoneg
Bericht 9 van 9
1.547 Weergaven
Bericht 9 van 9
1.547 Weergaven
Hi @Major_ToM .
No, Intel Driver & Support Agent did not work actually. There was no such an update or driver file indicated with Dynamic Tuning.
I've used a third party app: https://www.driveridentifier.com/ . And it worked!
BR,
Cem
8 ANTWOORDEN 8
