on 11.08.2025 20:22
on 11.08.2025 20:22
How can i enable them? I want to boost saturation and contrast so that I can see better in CS2 (Counter-Strike 2)
Thank you!
Also, i need the latest bios for my product. If any mods are here, please send the file.
on 13.08.2025 11:24
on 14.08.2025 10:58
on 14.08.2025 10:58
2408NP50RNCM1KAP2000538 is my serial number 😃 the bios was pre installed
on 14.08.2025 11:03
on 14.08.2025 11:05
on 14.08.2025 11:05
sorry, and the current BIOS version and any reason you need to update the BIOS?
You don't need to update your computer's BIOS or UEFI unless there is a specific feature or bugfix your system requires, or hardware changes. An error while updating your BIOS can brick your PC, rendering it completely inoperable.
on 16.08.2025 14:57
on 16.08.2025 14:57
My back plate Haß scratched off. Where can i find it and the BIOS?
Also the Nvidia display Settings are missing.
on 17.08.2025 18:19
on 17.08.2025 19:21
on 17.08.2025 19:21
Hello @Imran8 and welcome!
To find what you're looking for: Press the Windows key + R
Type msinfo32. Press Enter. There, under "system-sku," you'll find the MSN number: 300xxxxx.
Enter "bios" in the search field. You'll then find: BIOS version/date.
You can find missing drivers here:
should also be found on your computer under drive D
bye Fishtown
on 15.11.2025 23:30
on 15.11.2025 23:30
Hi brother! My system SKU is ML-210008 40089906
Also, although my battery health is 92% and it is plugged in, my battery is now stuck at 0%! It won't go up/charge. I'm trying to talk to my insurance company now. But i would appreciate the new BIOS.
