Medion Erazer Crawler E50i - NVIDIA Control Panel Display settings are missing & request latest BIOS
8 ANTWOORDEN 8
Imran8
Bericht 1 van 9
1.491 Weergaven
Bericht 1 van 9
1.491 Weergaven
How can i enable them? I want to boost saturation and contrast so that I can see better in CS2 (Counter-Strike 2)
Thank you!
Also, i need the latest bios for my product. If any mods are here, please send the file.
8 ANTWOORDEN 8
RAZZ
Bericht 2 van 9
1.456 Weergaven
Bericht 2 van 9
1.456 Weergaven
Hi @Imran8
please can you supply the MSN number of your unit (8 digits found on the sticker underneath) and the current BIOS version.
Have you cheeked the Medion Erazer control centre for settings?
Thanks
Imran8
Bericht 3 van 9
1.435 Weergaven
Bericht 3 van 9
1.435 Weergaven
2408NP50RNCM1KAP2000538 is my serial number 😃 the bios was pre installed
RAZZ
Bericht 4 van 9
1.433 Weergaven
Bericht 4 van 9
1.433 Weergaven
hi @Imran8
I need the MSN not the SN it is 8 digits long.
thanks
RAZZ
Bericht 5 van 9
1.432 Weergaven
Bericht 5 van 9
1.432 Weergaven
sorry, and the current BIOS version and any reason you need to update the BIOS?
You don't need to update your computer's BIOS or UEFI unless there is a specific feature or bugfix your system requires, or hardware changes. An error while updating your BIOS can brick your PC, rendering it completely inoperable.
Imran8
Bericht 6 van 9
1.380 Weergaven
Bericht 6 van 9
1.380 Weergaven
My back plate Haß scratched off. Where can i find it and the BIOS?
Also the Nvidia display Settings are missing.
Imran8
Bericht 7 van 9
1.319 Weergaven
Bericht 7 van 9
1.319 Weergaven
I want a way to unlock Nvidia display settings.
Bericht 8 van 9
1.310 Weergaven
Bericht 8 van 9
1.310 Weergaven
Hello @Imran8 and welcome!
To find what you're looking for: Press the Windows key + R
Type msinfo32. Press Enter. There, under "system-sku," you'll find the MSN number: 300xxxxx.
Enter "bios" in the search field. You'll then find: BIOS version/date.
You can find missing drivers here:
https://cdn.medion.com/cdn/download.pl?lang=de&filename=drv_Crawler_E50_Deputy_P60_w11.zip&id=23474&...
should also be found on your computer under drive D
bye Fishtown
Imran8
Bericht 9 van 9
402 Weergaven
Bericht 9 van 9
402 Weergaven
Hi brother! My system SKU is ML-210008 40089906
Also, although my battery health is 92% and it is plugged in, my battery is now stuck at 0%! It won't go up/charge. I'm trying to talk to my insurance company now. But i would appreciate the new BIOS.
8 ANTWOORDEN 8
