on 22.04.2024 19:42
on 22.04.2024 19:42
Hello,
I've bough the Medion Beast X40 2 weeks ago.
From the beginning, i've noticed that no sound were coming from the computer itself.
And I thought that no speaker were present.
I decided to contact the medion support in French which was poor as hell (No answer after promising to recontact me.)
When I retry writing with a agent, that agent told me "Return it to amazon, dont waste your time" lol.
I'm asking for help but i dont think they understand returning this type of item.
I've had many issues (For exemple, the touchpad lags. I have to close the laptop and reopen it to make the right side working again.
What makes me a little bit angry is the temperature. I'm buying a laptop that is expensive to be hot enough for cooking something on it while doing NOTHING.
I go up to 95 degrees on IDLE. And when i'm playing, it goes down (wtf).
But again, they said "return it" .
Could you please tell me how to make the speaker work ?
Could you please tell me about the temperature?
Thanks a lot.
MSN : 40085858
MD62507
S/N (i think its linked to my account.) : G*7PX*N2233**04**
on 01.05.2024 14:38
on 06.05.2024 21:46
on 31.07.2024 15:55
on 31.07.2024 15:55
The only thing you can do about the temps is undervolt your cpu in bios and then use a 3rd party tool to restrict the power. I got a stable undervolt of 1.29, that's -129 in the bios, but if i don't limit the power, games freeze and the odd BSOD occurs. Playing Starfield, I'm getting 100+ fps and the cpu temp only spikes over 90 degrees every now and then but mainly sits 70-80 degrees on max settings, idle 53-69 degrees. Best I could manage.
I've had the laptop 2 months. 2 months pretty much spent on learning how to lower the temps of the cpu. Definitely worth the hassle. This cpu is a beast and the gaming amazing once you've done the work.
X40
13900HX
RTX 4080
