How to enter bios menu ?? HELP PLEASE
17 REPLIES 17
kaanozkans
Message 1 of 18
Message 1 of 18
Hi guys i have an medion erazer 57001 gaming desktop,my question is how can i enter the bios menu for formatting my pc.i cant find it please help me
MSN number : 10023368
MD : 34664
17 REPLIES 17
kaanozkans
Message 11 of 18
Message 11 of 18
Are you crying baby boy :(((
Message 12 of 18
Message 12 of 18
@kaanozkans
No. definitely not. But you are impertinent. Stop this, or you will get into trouble yourself,
And teach yourself to make use of a more decent language,
Luke
Community Manager
Message 13 of 18
Message 13 of 18
Good Morning!
@kaanozkans:
Please stay on topic, and a feedback if our hints did help would be great.
@daddle:
Danke, mein Verständnis der englischen Sprache war bislang durchaus ausreichend. Es geht hier nicht um Wörter wie "f*ck", sondern um deine Attitüde.
@All:
This thread will be closed as soon as the problem has been solved.
Message 14 of 18
Message 14 of 18
Hi @kaanozkans ,
do you still need any assistance in your case, or can we close this one?
Greets
balanadi
Message 15 of 18
Message 15 of 18
I Would like to know how can i download the bios update for
MEDION AKOYA E6246 (MD63200)
MSN=30025987.
I was doing windows 10 update and after the bios update i forced stopped the laptop before finishing the update and now i need help .
I need a way to boot from usb , with the bios image so i can use the laptop again.
PLEASE HELP
Nalle85
Message 16 of 18
Message 16 of 18
Hi
I use to hold down "del and som F1,F2,F3" at the same time turn on the computer
and you will enter bios, some times you can tap this keys when the screen is going on.
I hope this will help you 🙂
Message 17 of 18
Message 17 of 18
Hi @Nalle85 and thanks for your reply.
In the most cases you get access to the Bios section by repeatedly hitting the "F2" or "Del" button (kind of a woodpecker would practice it😀), before the bootlogo appears
Cheers
neace_lacero
Message 18 of 18
Message 18 of 18
Hello,
I have useful information
I have laptop Medion E6247 - MD 61358
I managed to enter BIOS menu by clicking repeatedly F2 button at computer startup
Also I managed to enter Boot menu by clicking repeatedly F10 button at computer startup
Clicking repeatedly Del button doesn't seem to have any effect at all.
Pressing other major button like Esc, F1, F3, F4, F5, F6, F7, F9, F11, F12 also don't seem to have any effect
Similar setup can be in other models of Medion laptops
17 REPLIES 17
