Fans not working Correctly
52 ANTWORTEN 52
NinoR
Nachricht 1 von 53
22.525 Aufrufe
Nachricht 1 von 53
22.525 Aufrufe
I downloaded the new Control Center for my Medion Erazer x25 beast, and now the fast are not working properly anymore. When I want to set my own graph for the CPU I can barely edit it and it starts off all over the place. When I don't set my own graph the fan speeds stay at idle (31%) and dont go up even if the cpu is 95 degrees celcius. Does anyone know what I have to do?
52 ANTWORTEN 52
Cipri_MATASARU
Nachricht 41 von 53
3.837 Aufrufe
Nachricht 41 von 53
3.837 Aufrufe
Hello,
I follow this topic very close lately because my new X25 30031783 had the same issues with sound and video low performance. But, the solution presented in FAQ works for me and now, the computer came back on full capacity. this solve sound, graphics and some minor stuff like CapsLock key LED.
Thanks for proacivity!
gtsuit
Nachricht 42 von 53
3.828 Aufrufe
Nachricht 42 von 53
3.828 Aufrufe
The FAQ thing seems to have restored the Turbo mode, but I'm still not too sure about the GPU performance.
Regardless we should be given a choice to manually download machine breakers like this stuff. I am not inclined to trust this machine any more.
djupstrom
Nachricht 43 von 53
3.784 Aufrufe
Nachricht 43 von 53
3.784 Aufrufe
I have the same problem, one day my laptop just didn't have working sound and i also note my fans are not working. Maybe there is more things i haven't found out yet. I am not so good with computers, i just want it to work. I tried to do the fixes people used but nothing works for me, will there be a update that fix all of this or do i have to return this laptop to have a working one.
Any help is more then welcome!.
I feel like i paid for a gaming laptop that don't work. Am i understanding whats happening here correct... medion have some driver update in the background that don't work on release and make the gaming laptop not function properly and no official fix to it. Help me understand, it all just sound so dumb...
Cipri_MATASARU
Nachricht 44 von 53
3.771 Aufrufe
Nachricht 44 von 53
3.771 Aufrufe
@djupstrom ,
There is a fix method for your problem. it's easy to apply if you respect the steps detailed here. Important is to uninstall only the Control Center Service application from app list in Control Panel.
I have Medion Beast X25 model 30031783 with RTX3070 and reparation procedure worked perfeclyt!
Please try! Give a chance to this computer. I must admitted that the reaction of Support Center was pretty good taking in consideration that the number of machines sold is not very high. Please remember that kind of mistakes could happed, I'm referred to sending OTA an unchecked soft or FW. I remember even an huge company with a bite apple logo had this kind of issues few years ago. it's true, they solve the issue in few hours but...
Regards,
Schummi
Specialist
Nachricht 45 von 53
3.767 Aufrufe
Nachricht 45 von 53
3.767 Aufrufe
Hi @djupstrom,
Sorry for the inconvenience we have caused.
Please install the DMI-patch : https://community.medion.com/t5/FAQs/How-do-I-fix-faulty-audio-playback-on-my-ERAZER-Beast-X25/ta-p/...
This can be done without any risk and after a reboot most of your issues will be fixed.
Some minor issues that may affect the available options in your Control Center software can be fixed afterwards by following our FAQ:FAQ.
Both fixes are official but we are still trying to improve the workaround. Anyway, installing the DMI-patch is strongly recommend to fix all of your serious issues.
If you need further assistance please let us know.
Thanks.
djupstrom
Nachricht 46 von 53
3.751 Aufrufe
Nachricht 46 von 53
3.751 Aufrufe
Thank you both for the fast support and answer, i have my sound back and my fans are working again. That was very helpful! ❤️
Pavel
Nachricht 47 von 53
3.735 Aufrufe
Nachricht 47 von 53
3.735 Aufrufe
Hi all,
I have tried the steps and they worked only partially:
https://community.medion.com/t5/FAQs/How-do-I-get-back-missing-settings-options-in-Control-Center/ta...
I see 3 options:
Office, Gaming and Turbo, however I no longer have the option to control the W of the CPU. Before that  I was able to reduce or increase the W of the CPU as well as the BOOST.
Please, can you help with this, as it was very good feature and important for me to get optimal temps and performance, instead my CPU being automatically maxed out on W.
The other problems with the AUDIO and FANs are now fixed.
Would be great if in the future such thing happen, to be fixed automatically and not us to manually look for answers.
Revo
Nachricht 48 von 53
3.708 Aufrufe
Nachricht 48 von 53
3.708 Aufrufe
Hi Schummi,
Previouslly my fan was stuck at 30% speed and i am able to manually click the fan boost button to boost fan speed to 100% when i need to do something CPU/GPU intensive.
After a windows update yesterday, my cpu speed was locked at 0.38 Ghz, the fan seems to spin at maximum speed. I removed Control Center Service from my notebook according to your link https://community.medion.com/t5/FAQs/How-do-I-get-back-missing-settings-options-in-Control-Center/ta.... When I tried to use Defaulttool_BeastX25_234.zip ,my antivirus report malicious behaviour blocked with detection ID:SuspiciousBehavior.739487C72EEf16F. When i tried to download https://community.medion.com/t5/FAQs/How-do-I-fix-sudden-unwanted-effects-on-my-ERAZER-Beast-X25/ta-... my bitdefender saids:
"firefox.exe attempted to establish a connection relying on an unmatching security certificate to www.medion.co.uk. We blocked the connection to keep your data safe since the used certificate was issued for a different web address than the targeted one."
my device serial number is serial number starts with GM7ZG7P, ERAZER Beast X25 (MD 62307) MSN 30031969 , how shall i procced to fix the cpu speed lock and fan control?
sound playback also abnormal, the sound is strange may be due to low fixed cpu speed.
Thanks
Schummi
Specialist
Nachricht 49 von 53
3.685 Aufrufe
Nachricht 49 von 53
3.685 Aufrufe
Hi @Revo ,
not sure why your AV tools are blocking our sides but since nobody else complains about such issues I guess it must something wrong at your side.
I suggest to switch off the AV progam temporarily and download and install the DMI-Patch(oemserv-tool)first: https://community.medion.com/t5/FAQs/How-do-I-fix-sudden-unwanted-effects-on-my-ERAZER-Beast-X25/ta-...
If your CPU still stucks at 0,40GHz please try to use defaulttool, you may have to switch off your AV program again.
If you still have security concern you can upload the downloaded file to https://www.virustotal.com/gui/home/upload to check if they were reported as malicious.
After executing the tools you must reboot the device.
Last task: Install Control Center service again, reboot.
Please feedback if you CPU will still stuck at 0.40GHz afterwards, thanks.
Revo
Nachricht 50 von 53
3.667 Aufrufe
Nachricht 50 von 53
3.667 Aufrufe
Hi Schumi,
I uploaded the file MEDION-GM7ZG7P oemsevtool.exe to  https://www.virustotal.com/gui/home/upload
in the relation section there is something wrong with OemServiceWinApp.exe
https://www.virustotal.com/gui/file/90d3a1fe21f43a1baa8cb89fe2f3e2e8c3d883c7a89ab80458822479e112847d...
1 security vendor flagged this file as malicious
https://www.virustotal.com/gui/file/b029a19718ac9d25f37fb1fcbb6341607c398a75d8977f89e5299b046e656db7
Shall i proceed to run the program?
52 ANTWORTEN 52
