on 25.07.2024 14:52
on 01.08.2024 17:33
on 01.08.2024 17:33
dear @Mitcheroo
if you can confirm the MSN of the unit, it will be easier to verify, however to my knowledge there is no suck physical key but only through the control centre.
Thanks
on 09.08.2024 07:13
on 09.08.2024 07:13
Hiu @Mitcheroo ,
do you have an update on your current question? There are different ERAZER Beast X40 laptop models on the market, but generally you can adjust fan settings of the model in the ERAZER ControlCenter, wich can be launched by pressing the key combination FN + F2.
Cheers
