on 14.12.2022 20:23
on 14.12.2022 20:23
I recently bought a refurbished P10 erazer and I'm trying to change the RGB colours on the keyboard, it looks like I need to access the control centre by using the hotkey app however when I try to open the app a popup comes up asking if I allow it to make changes to the computer then nothing happens when I click yes. I have tried installing the hotkey driver software from the median website but that hasn't made a difference.
anyone have any ideas?
on 14.12.2022 22:06
on 14.12.2022 22:06
Hi @awindsor
did you restart the computer after installing the software and also start the control center as described here?
bye Fistown
on 14.12.2022 21:38
on 14.12.2022 21:38
Hello @awindsor and welcome
the specification Erazer p10 is too imprecise, there are so many different models. please name the MSN number of the device
bye Fishtown
on 14.12.2022 21:43
on 14.12.2022 22:06
on 14.12.2022 22:06
Hi @awindsor
bye Fistown
on 14.12.2022 22:28
on 14.12.2022 22:28
Hi
Just reinstalled again and rebooted and it works now.
Thanks so much for helping
on 11.01.2025 16:33
on 11.01.2025 16:33
Hello, i had trouble opening my control panel as well. I used to be able to open it by pressing fn+/ on the numpad but last time i tried it would load and i would see the logo of the app briefly appear on my task bar and then dissapear. and now it wont open at all anymore and my keayboars light has reverted back to the original color. Also its not the samle control panel that u have linked to, do u think u can help me?
11.01.2025 17:24 - edited 11.01.2025 18:20
Hi @Kwa_feur and welcome
EDIT: sorry, what I wrote refers to a different board manufacturer, you have a Deputy P10?
If your control center doesn't work anymore you have the same problem as many others in the last week. You can find a solution here:
bye Fishtown
on 03.01.2026 18:36
on 03.01.2026 18:36
Heya, im having the same problem, with the p10 MSN30029471 and i downloaded it from that link that you sent, however when i open it, it takes a while to load but then crashes and after that when i open it again it doesnt appear. Any idea?
on 04.01.2026 17:39
on 04.01.2026 17:39
Hallo @Ali786kreek en welkom!
Bedoel je de link uit bericht #4?
Heb je het oude Control Center al verwijderd? Dat zou je moeten doen.
doei Fishtown
