on 23.09.2020 19:43
on 23.09.2020 19:43
Hi all,
my Erazer X6603 no longer turns on.
I believe i left it unplugged and fully drained the battery.
It will no longer turn on; there is no charger light near the power cable input and it does not boot up.
the battery is integrated so i cant do the usual trick of removing power cable and battery and holding down the on button for 30 seconds etc.
is there anything i can do to fix this myself?
regards,
Grun.
on 24.09.2020 09:08
on 24.09.2020 09:08
Hi @GrunTed and welcome to the FORUM!
It may not be the battery. Have you tried a different power supply and/or a different energy socket?
If it does not solve the problem, then it would be a good idea to buy another battery.
Medion sells them at the spare parts website here and it accepts returns.
Regards,
Gehringer
on 25.09.2020 18:36
on 25.09.2020 18:36
Hi,
thanks for the reply.
The laptop is currently at a computer repair shop.
They have checked the power supply and socket and they are working.
I'll report back here once they have found the problem.
Cheers
Grun
Subject | Author | Posted | |
17.08.2024 15:14 | |||
26.04.2024 18:21 | |||
10.03.2023 22:50 | |||
12.02.2024 20:56 |
