Erazer X66006 - is there room for an additional SDD?
3 REPLIES 3
21Asala
Message 1 of 4
Message 1 of 4
I bought this for my son:
https://www.medion.com/gb/service/product-detail/10023462
Now he needs additional SDD (500GB - 1TB). I've tried to find information about the motherboard (which seems to be ECS B360H4-EM), but I haven't found information about if another SDD drive can be added. Is there room for it, can anybody help?
1 ACCEPTED SOLUTION
Message 2 of 4
Message 2 of 4
Hello @21Asala  and welcome
you have installed an M.2 / 2280 / PCIe / 512GB
and you can install an M.2 / 2280 / SATA on the free slot.
See also here:
https://community.medion.com/t5/FAQs/FAQ-Technische-Spezifikationen-f%C3%BCr-das-Mainboard-quot-ECS-...
Bye Fishtown
3 REPLIES 3
Message 2 of 4
Message 2 of 4
See also here:
Bye Fishtown
21Asala
Message 3 of 4
Message 3 of 4
Thank you for this comment, it was very helpful.
I have another question about the screw (that is needed to attach the M2 SSD drive): what is the right size of it? Apparently, the hole in the counterpart is so small that the screws that came with the computer don't fit in.
An alternative approach: Can the counterpart be replaced? It seems to be very tightly fastened (or even fixed) on the motherboard, so I did't feel comfortable to wrench it. So: Is it fixed or can it be safely wrenched off and replace it with one that is compatible with the screws that came with the computer?
Message 4 of 4
Message 4 of 4
Hi @@21Asala
You can find the answer here:
https://community.medion.com/t5/FAQs/FAQ-Spezifikationen-Mainboard-quot-ECS-B360H4-EM-quot/ta-p/9925...
For the attachment you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local specialist shops, you can find them in online shops.
Bye Fishtown
3 REPLIES 3
