Erazer P6679 battery not charging.
3 REPLIES 3
prolificgrace
Message 1 of 4
Message 1 of 4
Hello,
My battery is not charging, it says % available(plugged in). Can I remove the battery and replace it with a new battery?
Thanks. Help appreciated.
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hello @prolificgrace  and welcome
none is listed at the Medion service shop. look on the internet under P6679 battery
for example: https://www.akkubuy.de/akku-medion/medion-erazer-p6679-akku.htm
but can not say anything about the supplier, is your risk
bye Fishtown
prolificgrace
Message 3 of 4
Message 3 of 4
Thanks for the reply. Is it easy to remove the battery? There are a number of screws attached. Can't find any videos to demonstrate this and not on YouTube at all.  Any help, much appreciated.
Message 4 of 4
Message 4 of 4
Hi @prolificgrace
Easy, two screws, Look Here: time 3:50
https://youtu.be/6QPQAXKMMoA
Bye Fishtown
3 REPLIES 3
