Erazer P60 RAM Upgrade
11 REPLIES 11
pseudoSD
Message 1 of 12
Message 1 of 12
Hello I am having issues finding RAM that would be compatible with my P60 that I bought from here.
Anyone upgraded theirs and have a place I could buy the RAM? I should be able to install it no problem.
I want to upgrade to 32GB. Thanks
11 REPLIES 11
Message 2 of 12
Message 2 of 12
Hello @pseudoSD  and welcome
you can use any ram that meets the specifications:
DDR4 SO-DIMM (PC4-25600/ 3200 MHz)
For example: https://www.speicher.de/arbeitsspeicher-16gb-ddr4-medion-erazer-deputy-p60-ram-so-dimm-sp515232.html...
or you can ask where you bought the laptop yourself, they also have RAM:
https://www.laptopsdirect.co.uk/crucial-16gb-ddr4-3200-cl22-sodimm-ct16g4sfra32a/version.asp
bye Fishtown
Mastermind
Message 3 of 12
Message 3 of 12
Hi @pseudoSD ,
could you tell us, if you have an update on your RAM topic?
Cheers
Akossss
Message 4 of 12
Message 4 of 12
I just upgraded mine to 64GB. A simple process that takes DDR4 3200MHz laptop RAM. Just search for it, and pick one from Amazon, or ebay. Enjoy.
Penfold89
Message 5 of 12
Message 5 of 12
I am also looking to upgrade my Ram and have unscrewed all the screws but cannot get the base of the case off do you know how to do this without breaking the base case?
Akossss
Message 6 of 12
Message 6 of 12
Nice and gently. It comes of easily. All someone with experience, he'll show you where to begin...
Message 7 of 12
Message 7 of 12
hello @Penfold89  and welcome
state the msn and MD number of the device
bye Fishtown
Penfold89
Message 8 of 12
Message 8 of 12
Hello,
The MSN is 40089914 and its a Deputy P90 MD62705
thanks
Message 9 of 12
Message 9 of 12
Hello @Penfold89
DeputyP60 / MD62705
If I understand correctly, you have a barebones Clevo NP50RNE1 device.
You can find the service manual here:
https://drive.google.com/file/d/1s-U1G4ljs1NjCCrXnDQ3KBwlUpKhqMgT/view?usp=drive_link
bye Fishtown
tomka
Message 10 of 12
Message 10 of 12
Hi,
I bought this Medion notebook-PC few weeks ago, Deputy P60i MD62669 / NP50RND / MSN = 30038061.
I would like to upgrade the RAM from 16 Gb to more (24 Gb or 32 Gb).
Does it worth to upgrade from 2x8 Gb (16 Gb) to 16+8 Gb (24 Gb) ? Does the lose of performance due to dual channel (2x8 Gb) worth the upgrade of RAM (24 Gb) ? Is it quantified ?
Best regards, Thomas.
11 REPLIES 11
