Erazer Medion Deputy P10 Right Fan Rattling
11 REPLIES 11
Nomisra
Message 1 of 12
Message 1 of 12
Hi,
This just started tonight during a gaming session, the right fan is rattling slightly, definitely not normal, the fans were going at high speed at the time, and even now, at low speed, the fan is noticably rattling. Any ideas? Thanks
11 REPLIES 11
Gehringer
Retired
Message 11 of 12
Message 11 of 12
Hi @Nomisra ,
I am sorry to hear that you are having problems with your unit.
It is not clear to me whether you have contacted Medion team or the reseller but I will keep discussions on your particular case via PM exchange.
Regards,
Gehringer
Nomisra
Message 12 of 12
Message 12 of 12
Just an update,  laptop was returned with a new thermal unit,  it actually HAS seemed to quieten a bit,  no longer the jet engine 😉 and seems to work just fine.  Temps are good too.
11 REPLIES 11
