Erazer Major X10 Control Center
3 REPLIES 3
ruud68
Message 1 of 4
Message 1 of 4
I bought myself a Medion Erazer Major X10 where very satisfied. But I am Arch Linux user, used it for a while, suddenly I lost the Light in the keyboard. The light at the back of each device can change color and turn on and off, but not the keyboard. I remembered that the control center could turn off the lights behind and or the lights in the keyboard. But now my backup of the Control Center does not work. And can't find a download for it on Medion's website. fits all other laptops but not the Major X10.
Thanks in advance
Terje
2 ACCEPTED SOLUTIONS
ruud68
Message 3 of 4
Message 3 of 4
That I understand. Didn't quite know I was supposed to do that.
Take note and sharpen me 🙂
ruud68
Message 4 of 4
Message 4 of 4
It worked well. I got the light back on so now it works.
Had to install windows for and get this to it I think was a bit stupid.
I found a github project. which I will modify and create a gui, with the functions that I need. I'm retired now so it would have been cool to have something to do.
Is there anything that could be of interest to the community.
If you are going to install this program Medion CC, remember to turn off the virus program to install and approve as an unknown program. so windows does not delete it when you turn on the virus program again.
Hope it can be of help
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hi @ruud68
two same post and also via PM , I think once is enough.
https://community.medion.com/t5/Notebook-Netbook/Erazer-Major-X10-Control-Center-downloads/m-p/16157...
bye Fishtown
ruud68
Message 3 of 4
Message 3 of 4
ruud68
Message 4 of 4
Message 4 of 4
3 REPLIES 3
