Erazer E40 GPU failure (replacement board) ?
13 REPLIES 13
Lucienn
Message 1 of 14
Message 1 of 14
Hi,
My erazer e40's (MSN30035598, bought it a bit over a year ago) gpu stopped working for some reason, it does not show up in windows' device manager, I tried DDU, I also tried a lpsci on a linux bootable drive, no results. What I haven't tried is a windows hard reset.
The laptop never had issues before but a few days ago it just wouldn't boot so I opened up, and pushed the battery plug into the motherboard as it seemed it came a bit loose. That did the trick, it booted again but now the fans won't stop spinning after shutting it down, they only stop when pressing the power button.
I took special care that the laptop did not overheat, it was not very dusty when I opened it and I bought a stand so it could cool better.
I also opened it up to add a 2TB nvme, but that was almost a year ago.
13 REPLIES 13
popus_czy_to_ty
Message 2 of 14
Message 2 of 14
medion laptops doesnt come with 2 year warranty?
Lucienn
Message 3 of 14
Message 3 of 14
It does but I opened it up and switched the ssd ?
popus_czy_to_ty
Message 4 of 14
Message 4 of 14
it doesnt break warranty rules, in any respectable manufacturer/brand.
Lucienn
Message 5 of 14
Message 5 of 14
Hi again, support said that they won't do it if it wasn't the original ssd inside
Message 6 of 14
Message 6 of 14
@Lucienn
That's for the testing they want to do. In the original configuration. So if you still have the original SSD put it in and all will be fine-
If you put in a second SSD for more storage, it will not cancel warranty, because thats what the MB was built for, which you bought and paidfor.  . Incl. the right to extend memory, or put in a second SSD.
In which country do you live?
daddlle
Lucienn
Message 7 of 14
Message 7 of 14
Thanks for the response !
I live in France
The original ssd was lost to my messy brother
The new one is a 1tb crucial
Message 8 of 14
Message 8 of 14
@Lucienn
That's bad luck. In Germany I would argue, that exchanging the SSD for more storage capacity on the bootdrive happend long  agoa nd it functioned afterwars  ( if that's  the truth) .
And putting  a new drive in is part of the routine operatiosn which is basically allowed, eg for fitting in a second drive.
But first state the MSN Number of your laptop. It's on a sticker underneath.
Lucienn
Message 9 of 14
Message 9 of 14
The MSN is 30035598
I hope something can be done, this laptop is my main work station for uni, I need the GPU to run 3d modeling software
Message 10 of 14
Message 10 of 14
@Lucienn
Where  ís the mounting place for the boot SSD? Did you have to take the GPU  card  out, to change the SSD?
Then it's a bit more difficult to claim your rights.
And please note, I am no Medion employee, but a user like you.
You have to argue with the  Medion service center in France, or  with the reseller where you bought your Laptop.
But first I would do a hard reset. Drivers are actaully on your drive you gave to your brother, but should be on the Medion service page as well. After checcking with Clevo home page, I will send you a PN (Medion mail) i Check your mail symbol.
13 REPLIES 13
