Erazer Deputy P10 BIOS admin
1 REPLY 1
LucidDreams
Message 1 of 2
Message 1 of 2
Hi All,
When entering my bios with a blank password (the only way to get in) I have no admin access in the BIOS.
MD 61890 / MSN 30030055 / BIOS 209 (from windows system overview)
I noticed this just because I was going to upgrade my SSD, which worked, but then 99% of the BIOS is greyed out.
I am not the first owner, so if there is a non-blank password set I am unaware.
Can I flash something so I get full access ?
1 REPLY 1
Message 2 of 2
Message 2 of 2
@LucidDreams
It looks that some one except you had set an admin pass word before  you  put hands on the PC.. You do not have authorization to enter and change bios setup.
So  you have to ask them about it.
Or the PC must go to Service, tp get the orig.  bios flashed.
Cheers, daddle
1 REPLY 1
