Erazer Crawler e30 - standby/hibernate problem
8 REPLIES 8
little_pm96
Message 1 of 9
Message 1 of 9
Good morning everyone,
I recently bought this notebook and I noticed that if I close the computer screen when I reopen it the computer doesn't turn on.
To be precise, the keyboard lights are up and the fans spin, but the screen still black.
Could it be a bad driver?
Thank you!
1 ACCEPTED SOLUTION
little_pm96
Message 2 of 9
Message 2 of 9
EDIT:
(I can't find a way to delete or edit the post:)
I solved it, Windows Update had automatically downloaded an updated driver for the Intel graphics card.
I restored the original driver from the medion site and now everything works!
8 REPLIES 8
little_pm96
Message 2 of 9
Message 2 of 9
EDIT:
Mastermind
Message 3 of 9
Message 3 of 9
Hi @little_pm96 ,
that´s really nice to hear! So keepon gaming and have much fun with your ERAZER Crawler E30
Cheers
DBates96
Message 4 of 9
Message 4 of 9
Hi,
I have the same problem for my erazer E30 laptop. Where did you find the original driver on the medion website?
Message 5 of 9
Message 5 of 9
Hi @DBates96and welcome
On the one hand, you can usually find the drivers on the D drive if you bought it with the operating system
or enter your MSN number from the computer on the Medion service page, for example:
https://www.medion.com/gb/service/product-detail/30035526
bye Fishtown
little_pm96
Message 6 of 9
Message 6 of 9
Hi,
Search your model here
then
then download and install the intel graphics driver:
It should solve your problem!
DBates96
Message 7 of 9
Message 7 of 9
Hi,
I followed your steps and it worked! Thank you so much!
karinino
Message 8 of 9
Message 8 of 9
Hi, I am having the same problem with Erazer E30 Crawler and found the file on Medion site but as a novice I am not sure how to proceed. The folder I downloaded contains many files, can someone tell me which is the correct file to install.
Also, how do I know whether I need to install Intel or Nvidia graphics driver?
little_pm96
Message 9 of 9
Message 9 of 9
hello, if you have the same problem and you have downloaded the correct intel driver for your pc just run the .exe file as administrator:
install it and reboot your PC.
8 REPLIES 8
