Erazer Crawler E30 RAM Upgrade query
2 REPLIES 2
RustiNutz
Message 1 of 3
Message 1 of 3
Hello People,
I have just bought a rather lovely Erazer Crawler E30 (i5 12450H with RTX 3050)
I want to install more RAM. What is the best frequency MHz and CAS Latency you would recommend for this model.
Cheers,
Rusti
1 ACCEPTED SOLUTION
Message 3 of 3
Message 3 of 3
Hi @RustiNutz
Your PC is equipped with 8 GB RAM. See the specs:
1x 8192 MB DDR4 SO-DIMM (PC4-25600/ 3200 MHz) (1/2 Slots covered; 64 GB max.)
Those specs apply to all Crawler E30 Notebooks.
Which means you could add a second 8192 DDR4 SO-Dimm = PC4-25600 / 3200 MHz.
Or if you want more get two 16 or 32 GB, and replace the 8 192 MB. modiúl.
Cheers,m daddle
2 REPLIES 2
EastClintwood
Message 2 of 3
Message 2 of 3
Hello @raav,
Please send your MSN which can be found at the bottom of your laptop.
Regards,
EastClintwood
Message 3 of 3
Message 3 of 3
Hi @RustiNutz
Cheers,m daddle
2 REPLIES 2
