Eraser recon p10 wifi6 options
2 ANTWOORDEN 2
aRaS
Bericht 1 van 3
941 Weergaven
Bericht 1 van 3
941 Weergaven
Hi,
My MD 35068 comes without WiFi, so I want to add wifi6, as the router supports it.. There is no room to put a card in the PCIE 1x slot as it would block the fan intake for the GTX1650. What are my options? I find 2 M.2 slots but these do not seem suitable for an Intel AX200?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 2 van 3
938 Weergaven
Bericht 2 van 3
938 Weergaven
Hello @aRaS  and welcome
you have:
  • 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
  • 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
      and
  • 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
it is located between  PCIe x16 and PCIe x1 Slot
B460H6-EMB460H6-EM
bye Fishtown
2 ANTWOORDEN 2
Bericht 2 van 3
939 Weergaven
Bericht 2 van 3
939 Weergaven
you have:
      and
B460H6-EMB460H6-EM
bye Fishtown
aRaS
Bericht 3 van 3
930 Weergaven
Bericht 3 van 3
930 Weergaven
 Vielen dank!
This is my first pre-build so I hadn’t yet removed the grafics card to see underneath 🙂 To be honest I didn’t expect anything to fit there. I also couldn’t find the specs or even a picture online of the main board. I did see that someone on the forum had a m.2 WiFi slot on their Recon but it was an AMD main board.
2 ANTWOORDEN 2
