ERAZER ENGINEER P10 running at low ram speed
1 RÉPONSE 1
Infz
Message 1 sur 2
1 179 Visites
Message 1 sur 2
1 179 Visites
Hey,
When looking at task manager my ram is only running at 2667mz speed when it should be able to run at 3200mz. Why is it running at such a low speed and how can I make it go as fast as it should?
Name:
 ERAZER ENGINEER P10 MD34912
MSN: 10023715
Specs:
CPU: INTEL I5-9400F
COOLING:
AIR COOLER
MAINBOARD: INTEL B360 BASED
MEMORY: 16GB DDR4-3200
GRAPHICS: NIVIDIA GEFORCE RTX 2060 6GB
LAN: GIGABIT LAN
Balises (2)
1 RÉPONSE 1
Message 2 sur 2
1 176 Visites
Message 2 sur 2
1 176 Visites
@Infz
Hi.
Medion limits the ram speed to safe limits, through Bios settings and possibly by chipset ability.
So this keeps you on the safe side.
Even if the specs of the built in Ram are higher, it does not say it has to run at the highest speed possible.
Cheers, daddle
1 RÉPONSE 1
