ERAZER Defender P15 (MD 62293) UK MSN: 3003 3534 BIOS update?
4 REPLIES 4
ocelot07
Message 1 of 5
Message 1 of 5
Have owned this laptop for a few months. Recently having issues with games. For example playing the new Gears Of War Reloaded. I can play it on mutiplayer at like 90fps. But after a few games the FPS would drop to 60fps then after a few more games its running at a locked 45 FPS. According to CPU Z my Bios is 1.07.01RME1_00002 from 2021. Where can I find the very latest BIOS update please.
1 ACCEPTED SOLUTION
madalinext
Message 4 of 5
Message 4 of 5
Hello @ocelot07  I have the same laptop/bios  for about 4 years and I had no issues regarding the bios. I believe in your case is more like a problem due to overheating. Try to ensure proper ventilation by using a hard, flat surface and keeping vents clean and unobstructed and also use a cooling pad to improve airflow to see if that will improve or maintain your fps high for more time.
4 REPLIES 4
ocelot07
Message 2 of 5
Message 2 of 5
@Andi
Any chance you maybe able to assist?
Zephyrus951
Message 3 of 5
Message 3 of 5
Hi i have the Erazer Defender P15 Msn:30033285 and i am on bios ver. 1.07.03RME1 and require the latest bios update file
@Andi Any chance you could supply the bios file please ?
madalinext
Message 4 of 5
Message 4 of 5
ocelot07
Message 5 of 5
Message 5 of 5
You where correct @madalinext I did get the latest bios and it didn't change much. But a clean of thermal paste helped and fixed my issue.
4 REPLIES 4
