Driverpack and Control Center for Erazer P15811
4 REPLIES 4
demtibor
Message 1 of 5
Message 1 of 5
Hi Community,
I recently bought a secondhand  Erazer P15811-MD61775 ( MSN 30028713 ) that misses the original partition layout, hence no recovery or preinstalled software is present. Although i was able to put a fresh OS on it , in addition drivers were not an issue ... i still miss the erazer / medion control center that would allow me to change the keyboard backlit, etc..
Support site tells me to get everything through windows update ( ...or hunt for the drivers by yourself ) ....so would someone of you be so kind as to drop me a link to the right drivers / control center for this model ?
Thanks in advance !
BR
Tibor
1 ACCEPTED SOLUTION
Message 3 of 5
Message 3 of 5
Hi @demtibor and welcome,
Control center:
http://www1.medion.de/downloads/index.pl?op=detail&id=21217&type=treiber&lang=uk
Driver package:
http://www1.medion.de/downloads/index.pl?op=detail&id=19553&type=treiber&lang=uk
you have a clevo NH55RCQ-M1
useful manual5.pdf:
https://my.hidrive.com/share/yze8mg-wf8#$/CLEVO%20Service%20Manual%20Books/N_Series/NHxRx
bye Fishtown
4 REPLIES 4
sweetpoison
Message 2 of 5
Message 2 of 5
Welcome to the forum @demtibor
Until you can get a better answer try the software linked on post #4 from this thread https://community.medion.com/t5/ERAZER-Gaming/Erazer-x7851-Control-Center/td-p/79914
There are 50-50 chances to work.
Message 3 of 5
Message 3 of 5
Control center:
Driver package:
useful manual5.pdf:
bye Fishtown
demtibor
Message 4 of 5
Message 4 of 5
Thanks Mate, these are the stuff i was looking for.
demtibor
Message 5 of 5
Message 5 of 5
Fellas,
I have made a quick tour on that hidrive share and found it to be extremely useful if your Medion model is based on an OEM Clevo build-set.....
So if you need the initial driver pack or fresh Control Center versions, just check out for this share....
https://my.hidrive.com/share/yze8mg-wf8#$/Drivers%20Laptops
Cheers,
Tibor
4 REPLIES 4
