Do Medion Erazer P6689 laptops have a m.2 ssd slot?
3 REPLIES 3
K-ran123
Message 1 of 4
Message 1 of 4
My spec:
MSN: 30024221
Medion Erazer P6689 MD61001
CPU: i7-8550U
GPU: NVIDIA GeForce GTX 1050
RAM: 8 RAM (single)
HDD: 1TB
Hi, I'm planning to upgrade my laptop (ram and ssd) and I think it has an m.2 slot for an ssd?
The image link shows (what I believe) an ssd slot. However, here's the problem, I checked on crucial website and it only shows that I can upgrade to a sata 3 ssd which replaces my hdd. However I wanted to keep my hdd for files and an ssd for os and programs. Im now wondering if the slot I saw is not for an ssd 😕
I bought it from Laptopsdirect:
https://www.laptopsdirect.co.uk/medion-erazer-p6689-core-i7-8550u-8gb-1tb-geforce-gtx-1050-15.6-inch...
edit: if it does support m.2 ssds, does it support NV.MEs?
1 ACCEPTED SOLUTION
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @K-ran123 ,
your NB indeed have a M.2 SSD slot.
Regards,
Gehringer
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @K-ran123 ,
Regards,
Gehringer
K-ran123
Message 3 of 4
Message 3 of 4
@Gehringer thank you! Is it a sata or nvme if I may ask?
Gehringer
Retired
Message 4 of 4
Message 4 of 4
Hi @K-ran123 ,
The details are:
Form Factor: M.2 2280-S3-B-M
SATA Interface: SATA Revision 3
To be on the safe side, buy the card from a supplier which accepts refund/retun in case you have any issues.
Regards,
Gehringer
3 REPLIES 3
