Deputy 15 P1 Crashing
13 REPLIES 13
GTAH
Message 1 of 14
Message 1 of 14
Hello,
My Deputy 15 P1 is crashing when 5 mins into all games
-arena breakout
-delta force
so so annoying, how do i fix this?
W11 all up to date and same with NVidia graphics😡
Thnaks.
13 REPLIES 13
Message 2 of 14
Message 2 of 14
@GTAH
Hello,
please state the MSN number of your device. It's often on a  sticker on the bottom.
Or with MSinfo32.exe on the first page in the line System-SKU the last 8 digits.
Cheers, daddle
GTAH
Message 3 of 14
Message 3 of 14
 Hello,
My MSN number is:  30039889
 thanks
Message 4 of 14
Message 4 of 14
@GTAH
Ok thanks. How old is it? Since when  the crashing happens?
Did anything  extraordinary happens before?  Did you install new software or drivers?
But this will be a question for a moderator.  May be there is a new Bios.
Let's ask @Major_ToM . Please would you be so nice?  Thanks.
bye, daddle
GTAH
Message 5 of 14
Message 5 of 14
The laptop is really new, purchased in august.
I have kept everything update (not checked bios) see above graphics, w11.
and only ever installed steams games, predominantly crashes on the games mentioned above.
thanks.
Mastermind
Message 6 of 14
Message 6 of 14
Hi @GTAH ,
current Bios version should be V 1.07.02RME1. Could you please check, if this is the recent version you have installed on your machine?
Cheers
GTAH
Message 7 of 14
Message 7 of 14
@Major_ToM
hello,
No I have-   BIOS Version/Date INSYDE Corp. 1.07.01RME2_00012, 24/04/2025?
How do i update this?
thanks.
Mastermind
Message 8 of 14
Message 8 of 14
Hey @GTAH ,
think we can help out here with an actualized Bios version 1.07.02RME1, which can be downloaded here from the medion service portal
+++Installation instructions+++
Please proceed as follows:
1. Unzip the downloaded file 00_Bios_Deputy_15P1_Defender_17P1_Scout_15E1_17E1.zip into a directory of your choice on the hard disk.
2. Start the update process under Windows by executing the file FlashWinX64.bat in the BIOS folder by right-clicking with the menu run as administrator.
3. After the update had been installed andsystem has been restarted, the changes will take effect.
Disclaimer:
Please remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.
Your feedback is very appreciated to get your issue solved.
Cheers
GTAH
Message 9 of 14
Message 9 of 14
@Major_ToM   thanks BIOS Version/Date INSYDE Corp. 1.07.02RME1, 05/05/2025 is now installed.
I will run the games again later and test.
Wil update in a few days. ty
GTAH
Message 10 of 14
Message 10 of 14
@Major_ToM   was playing a long nicely, lasted a bit longer then crashed and got the below.
13 REPLIES 13
