Crawler E50 Technical Manual
5 REPLIES 5
Yui907
Message 1 of 6
Message 1 of 6
Hello, I recently purchased a E50, does anyone know if this comes with space for an M.2 drive or and additional SSD's?
I would love a technical manual or a service manual in order to work out what upgrades I can install
The model is:
MEDION Erazer Crawler E50 15.6" Gaming Laptop - Intel® Core™ i5, RTX 4050, 512 GB SSD
Tags (3)
1 ACCEPTED SOLUTION
Message 2 of 6
Message 2 of 6
Hi @Yui907 and welcome
you have a barebone Clevo NH50RNC1 and can put two M.2 SSD inside . One M.2 PCIe Gen4 x4 (SSD) + One M.2 PCIe Gen3 x4  (SSD)
I have uploaded a service manual for you here: https://drive.google.com/file/d/1s-U1G4ljs1NjCCrXnDQ3KBwlUpKhqMgT/view?usp=sharing
bye Fishtown
5 REPLIES 5
Message 2 of 6
Message 2 of 6
bye Fishtown
Yui907
Message 3 of 6
Message 3 of 6
Many thanks! I believe this laptop can support up to 64GB of DDR4 RAM at 3200mhz, correct?
IMG_20240429_183043 (1).jpgIMG_20240429_183048 (1).jpgIMG_20240429_183056 (1).jpgIMG_20240429_183057 (1).jpg
Message 4 of 6
Message 4 of 6
Hello @Yui907
According to Medion, it is only approved/tested up to 32GB:
https://www.medion.com/gb/service/product-detail/30036524
however, your CPU can manage 64GB and the service manual also speaks more in favor of 64GB.
So try it out. Do you really need that much RAM?
bye Fishtown
Yui907
Message 5 of 6
Message 5 of 6
Hi @Fishtown,
I spent so long wondering if I could, that I did not consider if I should.
 I'll let you know how it goes. 🙂
Yui907
Message 6 of 6
Message 6 of 6
Ram and M.2 install went fine, no discernable benefit though 😂
Thanks for all the help.
5 REPLIES 5
