01.08.2023 22:29
01.08.2023 22:29
I own an E10 Crawler, MSN: 30030079
Recently I noticed that, when i changed power modes in the control center, the actual power mode doesn't change anymore; It's always stuck on quiet mode. I reinstalled the control center but that just removed the icon and now I can't seem to find the actual app.
In the driver folder there's only the setup application (which I have done many times already) but not the control center itself.
Please help me out because I'd like to get rid of lag while gaming.
Thanks in advance
02.08.2023 22:39
02.08.2023 22:39
Hello @therealjojo and welcome
you have a barebone Clevo NP50DE
Here's a useful user manual, maybe this will get you the answers you need
https://www.file-upload.net/download-15174032/Manual_10133.zip.html
bye Fishtown
02.08.2023 12:31
02.08.2023 12:31
Hi @ therealjojo
please try to reinstall the control centre-
reinstall the updated Control Center service. The UniwillService_3.33.24.0_.exe file required for this can be downloaded from the MEDION Service Portal.
Afterwards the full options will be available in the ERAZER Control Center again.
02.08.2023 20:59
02.08.2023 20:59
Hello
I did as instructed, I had to uninstall the older version I had and reinstalled the files you gave, however I still cannot access the control centre. Where would I find the program and app?
02.08.2023 22:39
02.08.2023 22:39
bye Fishtown
03.08.2023 00:49
03.08.2023 00:49
Thank you for supplying a manual, however the solution to my problem is not stated.
I have gotten the control centre icon to show up, but it's called control centre3.0 package 2.25 and It doesn't do anything when I click on it.
03.08.2023 05:32
03.08.2023 05:32
Hi @therealjojo
it is installed but does not start via the icon. Does it open with the key combination: Fn + esc?
hotkey drivers are installed?
Bye Fishtown
03.08.2023 09:26 - edited 03.08.2023 09:38
I have similar issues on an X40 Beast.
It's my first time using the control center, no experience with previous versions, using latest bios.
The app is kind of invisible, so I can only launch it by running the installer and select Launch. The path of the app executable is somewhat obscure according to Task Manager.
Also the core voltage settings I set in the control center are ignored (attempting undervolting for better temps and on-battery performance)
Edit: Posted in another set, as this is set to solved / is a different model
