02.06.2021 20:39
03.06.2021 19:19
03.06.2021 19:19
Hi @eirikmars and welcome
look here:
Intel CPUs of the Comet Lake series for the socket 1200 to 65 W TDP can be installed.
bye Fishtown
03.06.2021 11:04
03.06.2021 11:04
Hi @eirikmars ,
I don't think it is possible to provide you a complete list of CPUs that are compatible for both upgrade or downgrade, but I can inform you which are the original CPU and MB so you can check compatibility with the manufacturer/seller of the CPU you are interested in.
Also, Medion can't endorse nor take any responsibility for modifications you perform on your unit.
CPU:
https://ark.intel.com/content/www/de/de/ark/products/199318/intel-core-i7-10700f-processor-16m-cache...
MB:
ECS B460H6-EM
Main feature: CPU socket: Socket LGA 1200 (65W max.)
Chipset: INTEL FH82B460
Type: internal
Technical kernel data: ECS B460H6-EM * RAM: max. 32 GB (2 slots) * Form factor: microATX
Interfaces / Connectivity: Back panel:
* 2x USB 2.0 Type-A ports
* 2x USB 3.0 Type-A ports
* 1x USB 3.1 Gen2 Type-A port
* 1x USB 3.1 Gen2 Type-C port
* 1x DisplayPort
* 1x HDMI
* 1x LAN (RJ45) port
* 3x OFC audio jacks
Internal Connectors:
* 4 x SATA 3 ports (4x black color)
* 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
* 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
* 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
* 1 x CPU 4PIN Fan header CPU_FAN (red)
* 1 x Sys FAN 4PIN SYS_FAN (white)
* 1 x Front Audio F_AUDIO with black plastic header
* 1 x Frontside USB: Cardreader with black plastic header (one port only),
* 1 x USB3.0 H10x2 front header F_USB31_12 (Intel pin out)
* 1 x Front_Panel header F_PANEL black plastic header
* 1 x 8PIN ATX 12V connector ATX_12V
PCIe slots:
* 1 x PCIe x16
* 1 x PCIe x1
Regards,
Gehringer
03.06.2021 19:19
03.06.2021 19:19
look here:
bye Fishtown
