Bios problem Erazer X7831
2 REPLIES 2
vivvas
Message 1 of 3
Message 1 of 3
Hi, for my sons laptop i bought new backlit keyboard MSI steel series. The backlit doesn't work, so I updated BIOS to latest version from Medion web site. Now the backlit stil doesn't work and the hot buttons (ventilator,P1,P2, backlit etc..) stopped working. The main problem is that i didn't made a copy of the previos Bios. Old bios was E1763IM7.50P / 1763EM7X(there is a blick on the picture of the last number) ver7.14.
Any one can help?
Medion Erazer X7831
MSN: 30018095
MD99032
2 REPLIES 2
vivvas
Message 2 of 3
Message 2 of 3
Problem solved.
Installed MSI GT70 dominator 2pc pro BIOS E1763IMS.50V.
And EC firmware from Medion 1763EM71 Ver7.15. Everything works even SteelSeries engine 2.9. The only problem is that i can't change the layers of the keyboard, but this is not a problem.
Jyselain
Retired
Message 3 of 3
Message 3 of 3
Hello @vivvas Thanks for sharing your findings. I am glad to hear you have solved the problem.
Kind regards,
Jyselain
2 REPLIES 2
