B660H7-M20 BIOS and iGPU
25 REPLIES 25
dot7ero
Message 1 of 26
Message 1 of 26
Hello,
i bought a MD 35354 with the motherboard B660H7-M20, i7-12700 and RTX 3060ti.
if I attach the hdmi cable into the motherboard port I have no signal and from the bios I don't see any menu to enable or disable iGPU.
Is it set to automatic into hidden options on the bios?
does it only work if there isn't graphic card mounted on motherboard?
can you send me the latest version of the bios that maybe fixes the problem?
I have version B660H7W0X.109
Thanks
25 REPLIES 25
dot7ero
Message 21 of 26
Message 21 of 26
i have another question . but I need expert.
if I want restore ECS bios wich options do you suggest me?
AfuEfix64.efi ECS.ROM /p /b /r /x /l
or
Afuefix64 ECS.ROM /P /B /N /K /X
in the first case not reset NVRAM but preserve SMBIOS and program all holes
- /L   Program all ROM Holes.
- /R   Preserve ALL SMBIOS structure during programming
in second case reset NVRAM but 'not program all holes'
- /N   Program NVRAM
- /K   Program all non-critical blocks and ROM Holes.
Thanks
dot7ero
Message 22 of 26
Message 22 of 26
but I think the best options are like this to reset the bios to factory ECS's settings
Afuefix64 ECS.ROM /P /B /N /L /X
dot7ero
Message 23 of 26
Message 23 of 26
I'm not sure if this option should be used too
- /CAPSULE Overrides Secure Flash policy on Capsule
Message 24 of 26
Message 24 of 26
@dot7ero
I am sorry. I do not know enough about bios and programming them,  I can not help you .
Good luck, daddle
Vince
Message 25 of 26
Message 25 of 26
MHDude
Message 26 of 26
Message 26 of 26
Hey, did you ever manage to install the original BIOS from ECS and if so, can you tell me how?
I have a similar problem and to fix it I need the BIOS from ECS installed, but I'm stuck on the Medion BIOS Version 112 I believe.
Thanks in advance 🙂
25 REPLIES 25
