Erazer X6819 Upgrade
3 ANTWORTEN 3
BoOoMSt1cK
Nachricht 1 von 4
28.401 Aufrufe
Nachricht 1 von 4
28.401 Aufrufe
Hi,
I currently have to Erazer X6819 MD97908 (MS16-F2 + GTX570) and what thinking about a graphics upgrade, I have been looking at Either GTX770m or GTX970m.
I have been reading forums and currently it is possible for MSI laptops with a modified VBIOS but not sure if i can do the same with my Erazer as it may be slightly different from the GT683 Which It is a white book of.
Can anyone help me on this as i dont want to waste money on something and Possibly damage my laptop
Thanks
3 ANTWORTEN 3
Nachricht 2 von 4
27.603 Aufrufe
Nachricht 2 von 4
27.603 Aufrufe
Hi @BoOoMSt1cK
we can´t recommend to swap the GTX 570 up to a GTX 770 or higher, because the whole cooling system is matched to this combination of CPU/GPU.Using a more powerful GPU would produce more heat, so that you also would have to adjust the cooling system to prevent the system from higher temperatures.
It may work with the current VBIOS, but I´m definetely not shure
BoOoMSt1cK
Nachricht 3 von 4
27.300 Aufrufe
Nachricht 3 von 4
27.300 Aufrufe
Is the GTX 970m not lower heat output and lower voltage?
I thought this would be my best option
Thanks
BoOoMSt1cK
Nachricht 4 von 4
13.795 Aufrufe
Nachricht 4 von 4
13.795 Aufrufe
Hi,
Just to let you know for future rreference - i did the upgrade via a guy in Canada on E-bay, i bought a GTX 970m MXM 3.0B card from the factory - he took the details of my Erazer and had the vbois flashed - i had to modify my heatsink a little bit and it works great!!!!
There is a noticible difference in performance and there is less heat (GPU max temp - 78 degrees) while gaming.
3 ANTWORTEN 3
